That is a different model number from the three DM repairs I have. Sorry this is not your problem with your TV set`. You have a differnt type of DM called A DM 3 board. No service info available even for the authorized repair peeps. You will need to contact the authorized repair shops to help you out with this i'm afraid. Good Luck with the repair.
Help.... As instructed, replaced all 7 capacitors with new XICON 16V 1000uF 105C Capacitors on my WS-65611. The actual desoldering / soldering was done professionally. Unfortunately my WS-65611 still has the blinking green light and does not power on. I did notice that the old capacitors on the DM board were not visually empaired or swollen as you have mentioned in the thread. Besides the cap replacement, is there anything else to check before calling it quits on my beautiful television?
William, there are some cases where the board is bad and the capacitor replacement does not fix the problem. However ther are a few things that need to be checked. There are small surface mounted fuses on the solder side of the capacitor board that do go bad sometiimes. You will need to take the service manual you received with the repair docs and test the voltages coming from the main power supply , goint to the DM. I have had a power supply problem in the past also cause the set not to work.
I am new to this forums, I am too a victim of this green blinking on my TV.
I did unplug the power for whole day and pressed the systen reset hole and nothing working. I might have the same symptom as everybody has.
Do you might if you send me a copy a intruction?
Here is my email. [email protected]
I have a mitsubishi WS-65611 with the green blinking light. My DM board is good but my FMT board, the board under the DM board is bad. I have checked the fuses and they are fine. Is there anything that goes wrong that is common on this board? Any information would be great. Is there any place I can buy this board from? Please email me at [email protected] Thanks Dave
I have been on the phone with Mitsubishi and found out about the FMT board prior to reading this post. I had a service techinician tell me it was a bad FMT board. I have had my DM module checked and the 7 capacitors and fuses are fine.The board under the DM module is bad. Mitsubishi called it a DM board. Model WS-65611 If this is correct is there any common things that go out that can cause the green blinking light? Thanks.
Larry can you email me the directions for the fix, I think my model number is WS-65869 or WS-65909, it just says "Medallion" on the front, doesn't say which model....Thanks!
My wife said she heard a pop the other day and kitchen lights flickered - had tv hooked up to a surge protector but now have blinking light. Tired usual wait hours and replug in, but no use. Tried self diagnosis test but couldn't get it to work either.
Had this problem previously and it finally worked after leaving it off for a day or two, but doesn't seem like it will happen now.
Could I also receive your email "fix" - thank, Larry.
Model WD-52725
Email [email protected]
Truthfully, I can't stand this tv and am sorry I ever got it - hardest tv to program I ever had.
Doesn't it seem like it's a manufacturer problem when you have over 400 posts regarding this??
no not really as you did get a one year warranty for the TV set and Mitsubishi did honer the warranty during the time period if you did have a problem. You knew the warranty on the set when you purchased the set right? You were the one that chose not to buy an extended warranty on the set. True, a TV set should last more then a few years but Now a days , they do not. The only way Mitsubishi would have to do a nation wide repair recall would be if it were a safety issue and this is simply NOT the case. It would be nice if Mitsubishi would answer it's problem, with these sets especially since a lot of folks spent several thousand dollars for them but they do not have to by law. Your problem is due to bad capacitors. Replace everyone I have highlighted in the pictures. Even if they look good, replace them. This repair will or should work on about 55 to 65 % of these model numbers of the DLP Set.
I have a WS-65611 unlike the post that I have read here, My green light actually stops flashing after about 30 to 40 secs. I am also able to run the diagnostics by pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds. The code returned is 12, which according to the service manual is an indication of normal operation with no Errors found. Yet, when I push the power button, I hear a click as if the set is going to come on and the green LED come on but, approx 5-10 secs later it clicks again and the green LED goes off and nothing. Any ideas?
You will need to measure the standby as well as the switched power supplies and see which one is not coming up and letting the set start. It could be capacitors in the main power supply or perhaps a problem in the regulator circuit. A hard call I'm afraid without more information.
Larry Dillon said: no not really as you did get a one year warranty for the TV set ... Replace everyone I have highlighted in the pictures. Even if they look good, replace them. This repair will or should work on about 55 to 65 % of these model numbers of the DLP Set.
Understood about the warranty, but if you're suggesting to replace with better components I guess they could have too. It's not as simple as replacing a lamp for most of us.
Did you email me pictures or are they somewhere in these posts? I will check out your suggestions, thanks.
Thanks for the quick reply. Would you be able to list points where I should measure the voltages and the values that I should find at each of these points? Your assistance is greatly appreciated.
George, I need an e-mail address and I will send you the service manual. That will show block diagrams on where the switched and the standby voltages are.
Larry Dillon said: Steven, I sent you the pictures as well as the service manual to help you out.
Thanks, but I cannot find an email from you regarding this. I also checked my messages on this forum.
I'm considering sending my DM board to PTS Electronics as some others have suggested. Anything I should ask them to do, i.e., replace ALL capacitors to prevent (uh, make that delay) future problems? It is $175 plus shpg. which seems reasonable, since i have no experience with this repair.
Again, my timer (power) light is constantly flashing on my WD-52725.
Do you have any service information on the WD-52825? Please send to [email protected] if you do.
Thanks.
I will send out that info to you in a short while. Good luck with the repair.
I saw your fix post and was hoping for some help.
The power to the house went down and now the little green light just flashes
WS-55859
Thank you.
JB597, I will send those repair documents to you shortly. Good Luck.
Thank You..
William ([email protected])
Will do as you as you suggested. Thanks for your time Larry.
Could you please share this fixit file with me. My email id: [email protected]
My model number is WS 65813
Hi Larry. I also have the green blinking light . Could you also send me the info. Model number is WS B55
My email is [email protected]
OK, I guess it's my turn now. We lost power last night and the Mits won't reset. The green light is blinking.
Model WD-52725
Thanks for your time.
My turn. The eternal blinking light problem.
Model WS-55613
email [email protected]
Thank you!
jprue, I will have that out to you ASAP. Good Luck with the repair.
Here is my email.
Much appreciate.
-- Kieng,
Already sent to you man. You only need to post in one thread.
There is no FMT board inside this set, what board is bad or who told you it was bad?
The part number for the DM board is 955C230002 for model WS-65611. Thanks
Another club i didn't want to join ;(
Model WD-52725
Thanks for your help.
Steven
George
Steven
email is: [email protected]
I'm not sure if you've sent me the information that I need but if you have, I haven't received anything either.
George
