Recently when I turned on my 42" projection tv, I heard a pop and the picture did not come on. There is sound, just no picture. I took off the back and noticed that the middle tube is not glowing as the other two are when the set is on. I also noticed that when I press the on button, the middle tube flickers and then goes out, but, the other two tubes stay on with a slight glow. What do I need to replace to fix this problem? Thanks, Gary
Mitsubishi wt-42413
Fri, 01/30/2009 - 14:55
Mitsubishi wt-42413
