I have seen various issues with Mitsubishi having fault code 22. I have the WT-46809 and it will not turn on. I have check the error code operation check and have the famous code 22. I was also having some vertical convergence issues prior to having the code 22 issue. I have replace the IC's ( IC8C01, IC8C02) and did find one of the pins cracked at the base of the chip so I hoping that will fix my convergence problem. What is you suggestion on fixing this code 22 or what Mitsubishi models tv are compatible with the WT-46809 so I can check past forums.
Just a heads up that this problem started when the house electricity clickered (not a surge) when the TV was on and has not worked since.
Any assistance would be greatly apprectiated.
Can someone Help!! I'm new at using forums.
