Rear projection TV STK 392-120 LG convergence problem
125 posts / 0 new
MBHEKISENI
ABOUT UNREADABLE RESISTORS
ABOUT UNREADABLE RESISTORS,ESTIMATE THE RESISTANCE OF THE RESISTOR BY SCRACHING SOFTLY THE OUTER COVER THEN,1 TEST THE RESISTOR FROM THE LEFT PIN TO THE FAULTY POINT THEN, FROM THE RIGHT PIN TO THE FOULTY POINT.eg: LEFT=cccccccccXcccccc=RIGHT. IF THE LEFT SIDE MAKES 14 OHMS AND THE RIGHT SIDE MAKES 4 OHMS THAT RESISTOR IS 18 OHMS.
Wasanthk
Rear projection tv problem
Hi, I'm having a LG Gallery rear projection TV. After using some times, now it takes long time to appear pictures. What should I do to rectify this problem?
Wasanthk
Hi Dayawansha,
Hi Dayawansha, Could you pl help me to tolve this problem? My rear projection TV takes long time to ahow pictures. Should I replace the bulb now or this occurs as a result of some other problem? Thanks
mgeonetta
Have a Sony kp-61v85
Have a Sony kp-61v85 convergence is bad repair manual calls for  stk 392-150 ic  Have there been any upgrades to this part?
