OUR NETWORK:TouchSmart Community TiVo Community Sling Community RoboCommunity My DigitalEntertainer MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 319347.0
April 24, 2008 01:29 PM
Categories: Portable Gaming
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
PSPfrEAk
Member
I have searched for psp themes and instructions in putting it in my psp(v.3.95). It says once you save to your desktop you can either save or drag to your THEMES FILE in your psp.When I save a theme and drag it to my THEMES FILE it doesn't show up on my psp(v.3.95). How do I get a theme on my psp(v.3.95)?
Discussion:    Add a Comment | Comments 1-10 of 10 | Latest Comment
Answers Post May 2, 2008 12:11 PM updated: May 2, 2008 7:55 PM
Well the file route has to be (exactly) x:/PSP/THEME. That is the routing I use, and it seems to work.
(X equals whatever drive the computer assigns to your psp/card)
If that fails to work, you probably have a "flash" theme, one that requires you to change your setting in the PSP program itself, which could potentially brick your PSP. Go to psp-themes.com, it has hundreds of good themes, and it gives good instructions on how to install them.
May 7, 2008 9:11 PM
thanks
May 7, 2008 9:28 PM
i try naming it exactly like you said but i doesnt allow the punctuations.
Answers Post May 13, 2008 2:33 PM
Ok, lets say you theme is named cool.thm (I think thats the suffix, not sure though)
1. You want to plug in your PSP or memory card.
2. Open "My Computer"
3. Open the E: drive (or F: if you have something using your E: drive)
4. Open (or make) a PSP folder
5. Open (or make) a THEME folder
6. Put cool.thm into the THEME folder you just made
7. Unplug the PSP or memory card (and insert the memory card)
8. Turn on the PSP
9. Go to "Theme Settings"
10. Open the "Theme" Tab
11. Your theme should appear below.
12. Select the theme you want
13. The PSP will get all think-y
14. and the theme will be set and work.
Did this help any better?
May 16, 2008 12:54 AM
uhmm i think my psp reads different kinds of themes..because i have to put .ptf at the end of the theme name to make it show up i my psp..thanks anywayss
May 17, 2008 12:04 AM
All PSPs read themes the same way. The suffix I used was because I couldn't remember the real suffix. If your PSP wont read the theme, its because its either a homebrew "flash" theme (which need custom firmware) or it's corrupted. There are no special themes for each persons' PSP.
View unverified member's comment - posted by marilooo
October 26, 2008 2:44 PM
Don't has what? God, you people seriously need to learn literacy skills. There should be a test before people are allowed on the internet.
November 27, 2008 8:18 AM
lol, take it easy.
my psp dont has either
November 28, 2008 9:52 PM
Has what? Do you want themes? What firmware do you have? Custom or Sony?
Discussion:    Add a Comment | Back to Top | Comments 1-10 of 10 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
