OUR NETWORK:TiVo Community Sling Community RoboCommunity My DigitalEntertainer MyOpenRouter MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 41695.0
March 3, 2008 09:50 AM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
efdjake
Member
I am new to this forum. I have a sony KP46wt510 that has no picture n o sound and the
timer/stand by flashes 8 times. Can someone tell me what this could be? Also, Is the kp46wt500
 the same as the kp46wt510? I have seen discussions on the 500 with the same problem.  Thanks
Discussion:    Add a Comment | Comments 1-8 of 8 | Latest Comment
March 3, 2008 9:56 AM
Check the High Voltage distribution block above the D board. The resistance to gnd should be higher than 40 mega ohms. To get the wires out, you need to push in and twist.
March 3, 2008 10:13 AM
What should the cost of an in home sevice call be in the North East, ball park? I am not a repair tech and I am trying to decide if I should fix this 6 year old TV or replace it. One place wants $150 to come out, then parts and labor are going to be more. If it's more than $500 total I might jusy as well buy a new LCD?
March 3, 2008 2:10 PM
The Hv block   is a likely cause. Although there could be other problems, like a bad flyback, or somthing in the flyback circuit, but usaly you will get either a 6 or 7 blink. If it is too far back in the circuit.
March 3, 2008 3:32 PM
Thanks for the advice.  Do you know if tha tis an expensive fix??
March 4, 2008 10:18 AM
It should not be that difficult if it is just the hv block. Should be affordable.
March 5, 2008 7:42 PM
It is a easy swap if you want to do it youself. The part cost 85$
June 19, 2008 4:12 AM
bwilbert said: It is a easy swap if you want to do it youself. The part cost 85$
Hi, bwilbert:
Do you know where to buy this D board for Sony KP-57WS510?
Wayne
June 19, 2008 10:20 AM updated: June 19, 2008 10:29 AM
First Check Q8043 HOT 2sc5778 if its shorted replace with Sony Part# 655014401 and RESOLDER T8006 pins on board Even if the solder looks OK on T8006 RESOLDER the PINS !
BUT if Q8043 is OK then HV Block could be bad Part# 859895532
SONY Parts>> >http://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
Discussion:    Add a Comment | Back to Top | Comments 1-8 of 8 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
