I have the same green blinking light problem with my wd 52725. Would this be a similiar fix to the 52525? If so could you send the files for repair to mderzio@sbcglobal.net. If not could you advise what the problem may be.
Mike
Hey Larry, is this my DM Board, I have a Model # WD52525
Posted in the wrong forum thread, just found this one. I have a WD-52525 with green blinking light when plugged in, and no response. Looking for DM cap replacement info. Thanks in advance.
Phil
pbatuk@gmail.com
On their way Mike and Phil. Good Luck
"Those who do not know their opponent's arguments, do not completely understand their own".
**For complete TV repair kits including parts goto www.TvRepairKits.com
Thanks for the quick response. Got the documents, and have been able to remove the DM board and others. Found 2 bulging caps on the DM, one on the FM. Caps are on order, should be replacing them this weekend.
Hope I can put it all back together!
Phil
pbatuk@gmail.com
View unverified member's comment - posted by skincutter
Hola Larry,
I appreciate the guides. Was a terrible pain taking this model apart! It is strewn all across my living room right now. I DID find some bulging caps on POWER PWB (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) Question. Are these numbers the Part Numbers for them? If not, can you help me with finding those numbers? I searched through the documents you provided but have been unable to produce any numbers for them besides the ones I have listed. Only those capacitors are needing to be replaced it seems.
Thanks again Larry.
Will_C_Young@hotmail.com
What do they say on the side of the capacitors?
The small bank of four say 1000 16v. the larger say 3300 10v. If that isnt whats your looking for, ill look again.
Yes, those are the part numbers you want to order. I spent some time figuring what to use for these capacitors. They are 6 volts higher in rating but I have had no trouble using them.
Ok, my new status:
Removed all boards. Bad parts were on the power bd. Changed those out under ths supervision of an electrician, put it all back together. A few left over screws. Now my "Status light" is blinking orange. Any ideas?
Larry Dillon said: On their way Mike and Phil. Good Luck
I replaced all suspect caps based on documents you sent (PWR, FMT, DM). Additonally, there was a bulging cap on the PWB-Signal board (330uF), so I replace that one too. Total of 15 caps. After reassembling and plugging in, it worked. Then after unplugging and moving back to home theater setup, back to green blinking light. Unplugged for 1-hour, still same result. Anything left to try or check? At this point, not sure if it's worth $1000+ to fix. Frustrating for sure. The documents were great, however - thanks again.
Phil
Will, usually, the flashing orange light means there is a bad bulb.
metaldog, I have had this also in the past and it turned out to be aditional caps on the power supply board. Now you will need to make some voltage measurments and see what is missing or not up to full voltage.
Larry Dillon said: metaldog, I have had this also in the past and it turned out to be aditional caps on the power supply board. Now you will need to make some voltage measurments and see what is missing or not up to full voltage.
OK, but not sure where to start. Are there any troubleshooting procedures to reference for this? I'm comfortable now taking it apart and reassembling, as well as replacing any components.
The set finally powered up last night after leaving it off for an hour for the 4th or 5th time, so as of this morning, it's working.
I appreciate the help and guidance on this. Please let me know how I can contribute to your cause.
Phil
WillTechSavy said: Ok, my new status: Removed all boards. Bad parts were on the power bd. Changed those out under ths supervision of an electrician, put it all back together. A few left over screws. Now my "Status light" is blinking orange. Any ideas?
I had the same "Status light" blinking orange. It was the filter door on the left lower side not being properly seated (there is an interlock switch on the lower right corner under the door).
Phil
perform the diagnostic test as described in the service manual and see what the lights blink. It will tell you if the filter door is the cause.
Hello. I just found this forum and this thread as my 52525 has just begun having the same issue.
Could you please send me the documents as well? I would greatly appreciate it.
tposey@samson.com
Thanks in advance!
OK. I reseated the door correctly for the filter. The power light started blinking (reloading itself I suspect) then went out. I turned the power on again, the power light stayed solid green like it would normally do. I waited for it to bring the display up. Never did. I rebooted. Same result. No screen. I am sure I am going to have to take this thing apart again (cringes) Any suggestions?
Take voltage measurments now. That is anbout all that can be done. Finfd out what is missing and we can go from there
Hello Larry,
THANKS ALOT FOR THE HELP!!! I received my new capacitors and swapped out the 4 on the DM board and 4 of the same type on the board next to it, one was bulding on that also.
Slapped it all together and it all came up fine.
Just thanks alot, always need an excuse to tear something apart.
Devin
you are very welcme man!! Do not forget to look at the service manual your were also given to see how the front of the tV set comes apart so you can clen out the optics. Makes a world of difference on a lot of these TV sets.
My WD 62525 is now experiencing the flashing continuous green light. Would you please send the service documents to
pjb1983@hotmail.com
Many thanks!
Sure Penny1983, Good Luck
Larry -
Can you email the service docs to me at jlaaking@msn.com? I have a WS-55513 that's having similar issues.
Will do man , God Luck withthe repair!
RSS
