OUR NETWORK: Dijit Community Explore3DTV My Open Router DVRplayground MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 1.09693E7
September 6, 2007 07:44 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
aerosvc
Member
My WS55511 Mitubishi will not turn on.  It power up for about 3 seconds and powers back down.  The green light blinks for a time if I hit the reset button, but it does not help the problem.  It sounds like the DM board problem that others on this forum have described.  I was hoping maybe someone could help me with obtaining the repair details on replacing the capacitors on the DM board.  I know how to solder OK and I believe I could do the repair, but I want to make sure I'm doing the right ones.  Can someone let me know how to get the repair instructions?  Thanks.
Discussion:    Add a Comment | Comments 401-425 of 776 | Latest Comment | « Previous 115 16 17 18 19 2032 Next »
June 15, 2008 9:35 PM
-Anthony pretty much the exact same thing is happenning to me but it't with the Red convergence instead of the blue, i replaced the pico fuses and put in a new IC chip and the problem did not change, so either i got another convergence chip with the exact same malfunction or there is another part i need to look at on my Ws-65511. If anyone knows anythgin about this one feel free to email me a link to the solution at jgurzell@hotmail.com
-J
June 18, 2008 12:49 AM
Hi Larry, A friend of mine has a WS55813 that has a constant blinking green light. She was told that it is the DM Port that needs replacing. Could you find the time to email me some suggestions or steps to repair this for her. My email is fpease5150@yahoo.com
June 18, 2008 10:05 AM
Tinman, on it's way to you. Good Luck
"Those who do not know their opponent's arguments, do not completely understand their own".**For complete TV repair kits including parts goto www.TvRepairKits.com
June 18, 2008 12:26 PM
jason- I found the problem with the convergence looking like an hourglass, one of the pins to the convergence modules needed to be re-soldered. I had to pull out the big board. Then look at the pins to the big IC's connected to the large heat sink.
June 19, 2008 12:43 AM
Thanks Larry, I'll let you know how it turns out for sure.
June 21, 2008 1:10 PM
I have a Mitsubishi WS-65411 and seems to be having a similar pattern reported here. Does it have any fix / workaround ?
samy r.
June 21, 2008 8:34 PM updated: June 21, 2008 8:48 PM
Hey everyone...
Thanks Larry for sending me the repair stuff a while back...I finally got a chance to work on this...and I got all the caps replaced...then went on to putting everything back together...and then I tore a ribbon cable =( now I don't know where to get a replacement...does anyone know where I can get this ribbon cable? It is one of the few white ones in my WD-52525 TV...it connected to the DM board...on it reads "SUMITOMO-M SWM 2896 80C VW-1 -F-"...does anyone know where I can buy a replacement? PLease help....on a side note...I am unable to locate the plug that goes into the PA slot on the DM board...Does this slot not have a plug on my WD-52525???? Thanks again, and hope to hear about these issues soon...
June 21, 2008 9:25 PM
Larry, I am in the same boat with the blinking grean light on my WD-55813. Power outage...unpluged TV and then Reset several times. It blinks for a while and then stops...blinks for a while and then stops...won't stop doing this.
Can I get a copy of the repair manual?
longhorn17@sbcglobal.net
June 22, 2008 3:14 PM
Aloha Larry,
I am also having the flashing green light problem. I have model number MB52525. Please send the repair info and instructions to mbryant808@hotmail.com I was wondering if this is a long term fix or will I have to do it again in a year or so? Since this tv was given to me, do you think I should attempt the repair or should I take it straight to the garbage dump? Any info would be greatly appreciated.
Best Regards,
Matthew
June 23, 2008 1:32 AM
Matt, I am running a little behind as I started an on-line class, I will get that to you ASAP.
June 23, 2008 7:27 AM
Longhorn, after you unplug the set and plug it back in, the light is suppose to blink for about 70 seconds or so then stop, what happens when you press the power button at that time? if the set does not come on try pressing the input and menu button at the same time and see what the light flashes, it should be a two digit code. It will blink the code 5 times then stop
June 23, 2008 7:30 AM
the PA is left empty, the only place I have heard to get the ribbon cable id from Mitsubshi.
June 28, 2008 1:39 PM
HELP!  I have that blinking green light problem too.  I have the Mitsubishi HDTV 1080 Model No. WS 55859 and was told by a tech that the portion of the DM board needed to be replaced and the part would run about $40.  Single mother and want to do it myself!!! Can you please email me the manual for this model as well as where I can call to order this part.  I just cannot fathom paying labor of $260 for a $40 part.  Thank you in advance for your help.
Email address is:  tbiz59@yahoo.com
June 28, 2008 5:22 PM
July 2, 2008 10:04 AM
Hey there Larry,
So check this out...I got the cap, and it was slightly bigger than the one it was to replace...but I think I replaced it fine...I managed to get everything hooked up, and I managed to get it all to go back into the TV...after getting all the screws back in I gave it a test drive...and I am back at square 1...the relays click...and there is even a TWEET sound that comes from the TV...the blinky light goes on for about 70 secs...then shuts off...and the TV does not turn on when I hit the power button on the front panel nor when I try to use the power button on the remote...when I tried to do the reset...I got the same result as before I took anything apart...The blinky light goes on infinitely...I ran the diag and it returned "12"...one thing to note is that I do not have anything hooked up in the back(no inputs nor cable tv hookup)...but i'm assuming that does not have anything to do with it...I'm a bit frustrated and very disappointed with my work...It seems like all that I tried did nothing...can you shed some light? Or did I just waste some money and a lot of time?
Thanks for all...
Paul
View unverified member's comment - posted by tidal
July 12, 2008 10:21 PM
Larry Dillon said: Sure I could send them to you if I knew your e-mail address. This repair has helped a lot of peeps fix their sets, but there are some that it does not. Always worth a try I guess.
larry please help another blinker....ws-48513....please send any info you got....you are a very nice person for taking the time to help with these issue....thanks for being that person larry dillon
July 14, 2008 4:43 PM
paulskii said: Hey everyone... Thanks Larry for sending me the repair stuff a while back...I finally got a chance to work on this...and I got all the caps replaced...then went on to putting everything back together...and then I tore a ribbon cable =( now I don't know where to get a replacement...does anyone know where I can get this ribbon cable? It is one of the few white ones in my WD-52525 TV...it connected to the DM board...on it reads "SUMITOMO-M SWM 2896 80C VW-1 -F-"...does anyone know where I can buy a replacement? PLease help....on a side note...I am unable to locate the plug that goes into the PA slot on the DM board...Does this slot not have a plug on my WD-52525???? Thanks again, and hope to hear about these issues soon...
Ok well,  I have not heard anything from anyone about what I should do next...I found the DM board and the Power Board on eBay totaling about $200...the people that refurbish the chassis had quoeted me $420 for the repair....should I try to still do this myself?  Is it even worth fixing?  I don't want to pay 200-450 for something that will just break down again in about 6 months or so....any ideas? Any response would be greatly appreciated...
Paul
July 16, 2008 10:46 PM
I too have the dreaded blinking green light timer problem. My Mitsubishi HDTV1080 is a WS-48513. Please help!
July 17, 2008 9:00 AM
Larry Dillon said: It could be DM Capacitrs or capacitors in the main power supply, there are also caps going bad on the FMT board as we speak. If you wish to see which ones go bad, but there is no garrentee this will fix your set, leave an e-mail address and i will share this wth you. Good Luck
Hey Larry, I've ben finally getting around to doing the repair on my Mits WD-62825 set. I have just about completely disassembled my TV, cleaned everything out really well and have the chasis removed with all 5 boards removed and ready to be repaired.
So far I have identified all the the Jamicon Caps 220uf and larger. I have also verified using the data sheets provided on Mouser what Caps can be replaced with one that is rated at the next highest voltage (because of the size difference). The main reason for this is that I also found a few Nichicon caps that are bulging as well. This could be a result of the other caps failing or it could be related to someone trying to save money and go with bare minium. Ya can't blame a company for trying to save a few pennies when you can save 10's of thousands of dollars when you use such are large quantity. Forgot to mention, the Caps that I plan to use are Nichicon Low Impedence type to provide an extra level of protection.
 Could ya please send the repair literature that you have to Deeked@verizon.net ?
Thanks for all your help.
 Dave
July 17, 2008 9:38 AM
Hi, Larry
I have a Mitsubishi WS-55511 with the blinking green light problem. I have pressed the reset button and the light continues to blink. I have unplugged the TV for 24 hours plugged it back in and the light still blinks.
Could I get a copy of the repair instruction and/or the service manual. My email is gsolberg@amatekinc.com
Thanks for all of you help.
July 17, 2008 3:43 PM
Another blinking green light. The model is a WD-52725. I downloaded a service manual. After reading some tech blogs, I went ahead and replaced the 4 caps on the DM board and board to the left of it (they looked blown also) After putting it back together...same thing. Blinking green light. Obviously I missed something. (power supply?) Any more info/instruction would be great. One more shot at it before I go shopping. The E-mail is yjb2254@gmail.com
Joel
July 17, 2008 4:32 PM
hello i have a mitsubishi wd52825 green light blinking. can you please tell me what caps to change and where in the set. thanks loharwado@aol.com
July 17, 2008 10:59 PM
Same message from before: I too have the dreaded blinking green light timer problem. My Mitsubishi HDTV1080 is a WS-48513. Please help!
Isn't there some capacitor kit? How can this be such a bad problem with only random solutions?
email is bonnie.marr@mercer.com
July 21, 2008 8:52 PM
Model WS-65869 Same story, please em instructions. Thank You it is appreciated ! remaxdon@hotmail.com
Discussion:    Add a Comment | Back to Top | Comments 401-425 of 776 | Latest Comment | « Previous 115 16 17 18 19 2032 Next »
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
