OUR NETWORK: Dijit Community Explore3DTV My Open Router DVRplayground MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 719939.0
May 3, 2007 08:57 AM
Categories: Home Theater Accessories
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Pending Member Avatar
Aziz Cheadle
Pending Member
I am the owner of a Philips TV model no PW 9527/105 and have had it for about 5years. My kids have now become older and I desperatly need to lock certain channels via my control, and seeing as I have never had the need to use the service before never tried it until of recent, and it is asking me for a code....I've tried 1234 and0000 thinking these would be the factory settings but to my dissatisfaction is not working. Can anyone HELP?
Discussion:    Comments 1-4 of 4 | Latest Comment
Answers Post May 3, 2007 10:47 AM
That means someone else has entered a code at one time or another.  You will need to clear out the old code.  Here are the steps for this: Philips:
Philips sets use a four digit code to control the v-chip.  The override code for Philip sets is 0711, although it may say "Incorrect code" the first time to trick you.  If "Incorrect code" is displayed, simply enter 0711 again.
To use it: hit the MENU key to get to the menus.  Go up or down until you reach AUTOLOCK or SMARTLOCK, depending on the model, and push the "right arrow" key on the remote.  Enter the override code, and enter it a second time if it says it is incorrect.
Once in the AUTOLOCK or SMARTLOCK menu, go to BLOCK, and push the "right arrow" key.  Go to BLOCKING OPTIONS and press the "right arrow" key.  Go to MASTER DISABLE and press the "right arrow" key so that it says "MASTER DISABLE      ON".  The v-chip is now deactivated.
 Now uou can go and block any channels you want and enter your own code, and if you ever forget this code, simply use the override code BUT keep it away from the kids.  You can get an owners manual for this TV set HERE Good Luck and let us know how you make out with this TV set.
"Those who do not know their opponent's arguments, do not completely understand their own".**For complete TV repair kits including parts goto www.TvRepairKits.com
March 10, 2010 4:06 PM
thanks i found away to get on the menu on the tv without a remote and the code 0711 did work thanks for your help
June 19, 2010 11:23 AM
Thanks 0711 works on my tp3285 c121, I was going crazy trying to unlock it.
June 19, 2010 11:25 AM
0711 works on my tp3285 c121, I was going crazy trying codes. Thanks again
Thread is locked, no more posts may be added.
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
