OUR NETWORK:TiVo Community Sling Community RoboCommunity My DigitalEntertainer MyOpenRouter MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 121785.0
January 28, 2007 04:57 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Silva
Member
Hi guys, this set RCA F25422 CTC203AC4, has a farely good pic and sound, but has this fault that i never saw before,When i go to menu it usualy has a blue square with a yellow line,but this one instead of the blue has just green barely can see the menu controls,and also the channel # has a small green square like the menu,it all started with almost full red kinda like when you have a crt board fault and clear up, i suspect caps, since i had this chassis as a spare not used it for long time.any ideas where should start to look for this trouble.Thanks in advance.
Discussion:    Add a Comment | Comments 1-6 of 6 | Latest Comment
January 28, 2007 10:11 PM
Find out from the schemstic how the menu gets injected into the video stage and you will find your problem.  Or the micro where the menu is comming from could be bad.
"Those who do not know their opponet's arguments, do not completely understand their own".
February 2, 2007 5:30 PM
Hi Help again,  i have this two caps that show short in my ESR,they just at the end of the micro, they come out of pin 26 of U12101the micro to ground,one is C12707 220uf35v,the other is C12707 a surfmout cap dont know value,i took out the electrolitic cap and out side is ok.the other one i did't take out but i assum that it willbe ok. could the micro be bad or the short could be some other place?any clues will be wellcome thanks.
February 2, 2007 5:36 PM
Hi i have a  RCA 52 inch HD projection tv.....anyone know anything about it just powering off when it wants. at the moment it last about 20 mins before it powers off. have to let it sit a few mins then then we start the process over and over. ok more info 52 inch model is D52w25 chassis ITC222.  And am I asking this question in the right place?
February 2, 2007 6:21 PM
Silva, scrap off the clue and replace BOTH caps. There is a service bulliten on this problem. I had this on another thread man.  With the replacement caps also.
February 2, 2007 6:31 PM
Larry do you know the value for the c12707 Sm can't reed the value.thanks in advance
February 3, 2007 1:06 AM
Nope sorry I do not have a value or the service manual.
Discussion:    Add a Comment | Back to Top | Comments 1-6 of 6 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
