OUR NETWORK:TiVo Community Sling Community RoboCommunity My DigitalEntertainer MyOpenRouter MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 124665.0
December 24, 2006 07:24 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Silva
Member
I have a RCA CTC 113AA, F20TF20
I need to adjust grey scale in service menu, I can get in , has some one the manual and give me please at least what are this.
6 = 7= 8= 9= 10= 11= 12= 13=
Discussion:    Add a Comment | Comments 1-11 of 11 | Latest Comment
December 25, 2006 9:57 PM
Sure you got the right chassis number my freind, as this is an old set if it is.  Is it a 200  chassis seires?
"Those who do not know their opponet's arguments, do not completely understand their own".
December 25, 2006 10:40 PM
Please post the model number and full chassis number.  Any details you can provide will allow us to get you more detailed responses.
Dan
December 25, 2006 11:00 PM
Yea! What Dan said LOL
December 26, 2006 11:25 AM
Ok.. I found out a little more info here.  The chassis number is ATC113.  The unit was made sometime in 2003.  I should be able to get the service info.
December 26, 2006 12:02 PM
Oh thats differant then! An ATC chassis. Not CTC.
December 26, 2006 2:51 PM
Thank you Larry, your're right my mistake , the chassi is ATC113AA1,RCA.
December 26, 2006 2:58 PM
dans the man, he found the right model number.
December 26, 2006 3:10 PM
I don't have the service manual for that one readily availble at this time. I'll try and get it though. Since my main specialty is audio products and camcorders (vcrs too), I don't save the TV stuff locally.
December 26, 2006 6:50 PM
Thanks Larry, this confusion  happens to me many times,i had it right on paper, but when i wrote it here, i wrote it wrong,  maybe because i'm used to the CTC 's which i like better then some RCA crap they make now like the ATC's. I think my problem here is the flyback, because when i adjust  g2 low bright the way i like it  kind change the convergence grey scale , and when i turn on ,the screen takes 3 or 4 seconds  to bright the pic up, i have to keep g2 adjusted a litle bit too higher for my test,
December 26, 2006 9:34 PM
I would check the regulator for ripple in the main power supply.
Discussion:    Add a Comment | Back to Top | Comments 1-11 of 11 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
