OUR NETWORK:Dijit Community Explore3DTV My Open Router DVRplayground MediaSmart Home See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 684980.0
October 5, 2006 05:37 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Greg0915
Member
Our Sony Trinitron XBR picture went blank and the red blinking light indicating the TV went into standby mode.  What can I do to get the light off and the picture back?  The sound is still there.  Thanks
Discussion:    Add a Comment | Comments 1-7 of 7 | Latest Comment
January 5, 2007 3:38 AM
My 27" Sony Trinitron XBR's color became mixed, i.e., the picture is clear, however, the color has changed. People's faces are a light green. There's more purple. The only control I have is with the remote. What do you think is the problem & how can it be repaired? Cost?
January 5, 2007 3:41 AM
Greg0915 said: Our Sony Trinitron XBR picture went blank and the red blinking light indicating the TV went into standby mode.  What can I do to get the light off and the picture back?  The sound is still there.  Thanks
A friend of mine had a similar problem and a repairman simply replaced a chip. Cost = approx. $70.00
January 5, 2007 9:23 AM
It sounds like since you still have sound on this set, that you could have a problem in the vertical sweep circuit, or in the video processor circuit of the TV set.  I have also seen the High Voltage block cause a no picture condition.  Also there is a small resistor off of the flyback transformer that will heat up and you will get a bad solder connection or the resistor will go bad.  This resistor goes to the filiment of the piture tube(s).  Does the Light flash in any order or random?  What is the model number?
"Those who do not know their opponent's arguments, do not completely understand their own".
**For complete TV repair kits including parts goto www.TvRepairKits.com
January 5, 2007 9:27 AM
Nate Dog,  what does the picture look like when you lower or turn off the color all the way.  If the screen or when you watch a B&W movie or show on the TV set, and the picture Without the color looks purpleish, or a differant color, and not B&W, Most likly there is a problem with the picture tube, the auto kine bias circuit, or in the RGB driver circuits.
January 7, 2007 1:38 AM
Larry Dillon: When I turned the color off, the picture on the screen is black and white... no other colors, no hue, no tint, just black and white. The picture is still clear.
January 7, 2007 8:50 AM
It is probably a fault in the color processor circuit since the set has a good B&W picture.  this could be a almost anything in that circuit .. Whats the complete model number?  And chassis number?
January 9, 2007 1:25 AM
Larry Dillon: Thank you for your response. The Model No.: KV-27XBR50, Serial No.: 7000B71, Manufactured: May 1990. I couldn't find a chassis number. What are we looking at as far as a color processor circuit? Again, thank you for your response.
Discussion:    Add a Comment | Back to Top | Comments 1-7 of 7 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
