OUR NETWORK:TiVo Community Sling Community RoboCommunity My DigitalEntertainer MediaSmart Home Pogoplugged See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 221324.0
January 16, 2006 02:32 PM
Rating (0 votes)
Rate This!
Member Avatar
arpeggio6408
Member
I have a MAG LT916s Model #900P monitor and it has started going to a black screen.It will boot correctly but once in Windows it will just go black. If you turn it on and off it will come on for a few seconds and then go black again. I am running Windows XP media center edition. The computer and monitor are only three months old. I have adjusted the power save to never for the monitor. I hooked up an old monitor, an EV700, and it works just fine. What do I need to do to fix this? Thank you in advance for your help.
Discussion:    Add a Comment | Comments 1-2 of 2 | Latest Comment
February 7, 2007 11:36 AM
I see that you posted this a year ago, but I am now having the exact same issue my my MAG 900P.  It powers up and then goes blank.  Pressing the power button 4 times results in it powering up again for 2 seconds.
Any help in finding replacement parts would be great.  My monitor is 14 months old and is thus out of warranty.
Thanks.
February 7, 2007 8:25 PM
This problem is usually due to a connection problem at the CRT board.  Open up the unit (with it unplugged!) and check the connections at the connector that is on the board on the back of the picture tube.  The cable that connects to the computer should end up here.  These connections often go bad because of heat/cold and without the detection of a signal form the computer, the monitor will shutdown (power saving).
Dan
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
